STRINGS AND FILE I/O
Hi Billko,
             The setup you showed only displayed the only the number corresponding to the first 2 characters of the string. The rest of the string did not have any effect. Is it supposed to work this way?
Thanks.
Vincent
Message 11 of 17
(1,721 Views)
Hi SSHADOR!
The tables on the snapshots are array constants. You can create in the diagram block (rigth click > Array > Array constant). Then you put inside a numeric constant (blue table) and string constant (pink table).
Regards!
Message 12 of 17
(1,719 Views)
Message 13 of 17
(1,693 Views)
Hi Paul,
            The figure you gave only displays one character at  a time.
Vince
Message 14 of 17
(1,681 Views)
Hi Jimbe,
              Please see the attach. It did not work for me. I am confused now.
Message 15 of 17
(1,679 Views)
It does not work for any of us, because it is just a picture. We cannot run a picture.
Please attach the actual VI instead.
(event structures belong inside a while loop and not vice versa. You were told to use a FOR loop because the number of iterations is known before the loop starts. You string does not have any spaces, so why does your format have them? ...?)
Message 16 of 17
(1,668 Views)
@SSHADOR wrote:
Hi Jimbe,
Your Scan from string looks for 2 characters and then a space. Unless you write your number as lu su ke it won't work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 17 of 17
(1,648 Views)
