SVXMPL_WAV Recorder (DAQmx) cannot locate key .vi files.
I have Labview 2010 and NI Sound and Vibration Suite and Toolkit installed on Windows XP.  Using a USB-4431 I want to record output into a WAV file.  Upon attempting to use  SVXMPL_WAV Recorder (DAQmx).vi the following .vi's were missing, and nowhere on the system:
DAQmx Fill in Error Info.vi
DAQmx Start Trigger (Analog Edge).vi
DAQmx Trigger.vi
DAQmx Clear Task.vi
DAQmx Control Task.vi
DAQmx Timing (Sample Clock).vi
DAQmx Timing.vi
DAQmx Create Channel.vi
DAQmx Create Virtual Channel.vi
DAQmx Read (Analog Wfm 1Chan NSamp).vi
DAQmx Read.vi
I even reinstalled everything (with all check boxes fill in the installation), and they are still missing.
-Ryan Pifer
Physics Dept.
Naval Postgraduate School
(4,182 Views)
Hello Ryan
The VIs in question should get installed with the DAQmx driver. You may have installed a driver version that does not have support for LabVIEW 2010 in which case you can download a supportable version from ni.com/support. DAQmx 9.2.1 appears to have support for LabVIEW 2010, this information can be found in the ReadMe. If you continue to have issues please provide the MAX configuration file.
Hope this helps.
Glenn M
Glenn
(4,161 Views)
I also having the same problem as Jay@NPS. I have a several files that use the Labview 8.6 version. And I have installed the same version on my computer. Using USB 6009, I want to record electromagnetic signals. However, whenever I want to open the file, there are some .vi's missing from my computer.
-Wan Izzati
Postgraduate Student
(3,925 Views)
Hi Wan Izzati,
Are you missing the same VI's as Jay@NPS? If not would you mind listing the names of missing VI's? What is the version of DAQmx drivers installed on your computer?
Best Regards,
Jignesh P
Best Regards,
Jignesh Patel
Principal RF Software Engineer
(3,915 Views)
