07-13-2011 07:04 AM
Hi all,
I have this issue, I added a DAQ assistent and the channel works properly, but when I click ok the Data tab is not there, so then I can not use this to do any thing, But in other machines with the same software it works properly..
Do u have any idea about this..
OS-XP
Labview 8.0
Gaya
07-14-2011 10:17 PM
Hello Gaya,
Are the two machine identical hardware wise? You may need to repair the DAQmx installation. To repair the DAQmx follow the instructions on this link. The KnowledgeBase article talks about repairing LabVIEW, however instead of selecting LabVIEW you will be selecting DAQmx.
Best Regards,
Jignesh
