DAQ assistant does not have data inputs or outputs
Hi all,
I have this issue, I added a DAQ assistent and the  channel works properly, but when I click ok the Data tab is not there, so then I can not use  this to do any thing, But in other machines with the same software it works properly..
Do u have any idea about this..
OS-XP
Labview 8.0
Gaya
(2,311 Views)
Hello Gaya,
Are the two machine identical hardware wise? You may need to repair the DAQmx installation. To repair the DAQmx follow the instructions on this link. The KnowledgeBase article talks about repairing LabVIEW, however instead of selecting LabVIEW you will be selecting DAQmx.
Best Regards,
Jignesh
Best Regards,
Jignesh Patel
Principal RF Software Engineer
(2,287 Views)
