Same font "Tahoma: pt 8 seems Different in LabVIEW 2009 and MS Word (EXcel,Windows, Menu bar
I have developed an application in LabVIEW 2009, which exclusively uses "Application Font" for every where in Block diagram and FrontPanel. From LabVIEW.ini I am goon to set appFont="Tahoma" 8
Because when I look at my Computer, Display Properties>Appearance>Advance>Item=Menu then it seems that It uses Tahoma 8Pt.
But When I look at Windows Menu and My LabVIEW Application both are very different with respective to font.
Could anybody attempt to this answer this question?
How do I make both same in apperance?
Is LabVIEW has different font set and setting that Windows ??
Regards
Hemant
hemantpardeshi@gmail.com
(4,280 Views)
In our World all things are relative...
Probably here difference between French points and American points? 😉
http://en.wikipedia.org/wiki/Point_(typography)
http://en.wikipedia.org/wiki/Pica_(unit_of_measure)
Anyway 8 pt Tahoma in Windows is according to 13 pt Tahoma in LabVIEW.
Also may be difference coming from MacOS.
Andrey.
(4,264 Views)
Accepted by Fuzzy Me
Nice thing, never think about this before...
Anyway here table of differences: (MS Write vs LabVIEW):
 Andrey.
(4,254 Views)
Hi Andrey,
Thanks for quick turnup. I corrected my applicationas per your snapshot. But still Tring to findout Exact reason of Font size diffference between Windows and LabVIEW.
May be Darren could help out inthis 🙂
Regards
Hemant
(4,232 Views)
