Sample an an Analog input from my PXI-7841R DAQ
I want to sample an Analog Input from my PXI-7841R  AI0.  The issue I am having is when I drag the input from my project into my VI, the item is set as a Signed Integer value and I cannot change it to a floating/double.  Why is this?  I am experienced with LabVIEW; however, this is my first go developing LabVIEW FPGA.
Please help! thanks!
(4,067 Views)
The analog inputs on an FPGA are giving you raw, unscaled binary values.  So I16's.  (FPGA's are much more efficient with integers than floating point numbers.)
You will need to scale the data to a floating point, such as on your host machine, if you need a scaled floating point value that represents engineering units such as volts, or something else.
(4,065 Views)
Yup, send the I16 value to a host RT or Windows machine using a DMA FIFO, or just read the front panel control value if you don't mind the slowness, then scale it for the range you want.
(4,060 Views)
Accepted by topic author altran
Got it. Thanks.
So the manual provides me this forumla:
Raw = (Voltage x 32768) / 10.0v
So if I wanted to compare the Analog input to a value of 1.5 Volts,  I could use the formula to get the Raw value of 1.5v and compare it to AI0 directly on the FPGA correct?
(4,052 Views)
That looks about right.
(4,025 Views)
That's what I do and it works quite well.
(4,005 Views)
Thank you all!
(3,984 Views)
