Sampling Rotary Encoder- Error -201319
Hi all,
I am trying to sample voltages while using the rotary encoder as my sample clock. Every time the encoder rotates a degree it outputs a signal and I'm using that signal to sample values at that instant.
I keep getting Error -201319:
Possible reason(s):
Sample Clock pulse occurred before the previous sample was acquired from all channels in the task. Use a Sample Clock rate that allows time for the device to acquire samples from all channels. If you are using an external Sample Clock, ensure that clock signal is within the jitter and voltage level specifications and without glitches.
My program is shown below:
(6,015 Views)
Update:
I have solved this via a Digital Filter through the timing diagram property node.
(6,000 Views)
Could you explain or show how you solved this problem, maybe attaching a imagen of your code?
Thank you so much.
(5,569 Views)
Thank you so much.
You are replying to a 2 year old thread.
However, Its worthwhile to come back at this for clarity.  I will make some assumptions about the OPs situation.
Likely, the OP encountered some glitches coming from his rotary encoder (Not too surprising considering that there would be vibrations in the rotary encoder's shaft that would manifest as glitches on the rising and falling edges)
Enabling digital filtering of the sample clock sourced from that encoder would ignore the glitches until the pulse width was at least 1/2 of the min width specified in the filter. available from the DAQmx Timing Property node
(5,564 Views)
Hi Jeff,
First, thanks for the answer, also could you show me an example for using this property node, as location inside block diagram and connection for correct operation?
Thanks again.
(5,558 Views)
 I'll make you this deal.
Show code by snippet tell us what hardware you  are using and explain what you see.  I'm on a phone so.... no LabVIEW.
(5,552 Views)
Hi Jeff,
I am acquiring a pressure signal from an internal combustion engine timing by an external clock (encoder), code starts to acquire but after a moment this stops and show two error types 201319 or 200019. Hardware is PCIe-6351 for data acquisition.
(5,533 Views)
