Saturation add
I see that "Saturation add" is no longer supported by Labview. Now how do i sum two I64 integers with saturation?
(4,971 Views)
I don't recall ever seeing Saturation Add.  Was this part of an add on library?  If so, was it installed during your last installation of LabVIEW?
R
(4,961 Views)
(4,950 Views)
Accepted by Snamprogetti
The fixed-point data type and native add function have assumed the functionality previously provided by the Saturation Add. You'll need to convert the inputs to the equivalent fixed-point type <s,64,64>, then pop-up on the add function, choose properties and configure the output for <s,64,64> with overflow mode set to saturate.
(4,946 Views)
