Save 1st array in For-Loop for remaining execution cycles.
I have a function embedded in a N=65 For loop which pulls-down real time array data.    On the very first loop, a "calibration" array is created which needs to be saved as a reference for relative measurements in the next 64 executions.
Does anyone know what I need to do to save this first set of data, so I can keep using it?   On the next run, the function pulls completely new data, and naturally overwrites.
At the moment, i do not have a source VI to post (that works), sorry about that.   Will try ot get something up tomorrow....but it will likely not be working.
(4,080 Views)
Shift register
(4,074 Views)
Accepted by SparkyOne
To be a little more exact...
(4,045 Views)
I knew I was making this task -WAY- too complex.
I had a similar function on another VI I had created....and did not understand why it was not working in this case.   Shift Registers FTW.
(4,031 Views)
