Save HDF image in LabVIEW
would like to store some image data from a 2D-Picture control to an HDF file using the marvelous Live HDF5 package. However, I was not able to save the data in such a way that HDFView recognizes them as "Image" datatype. I tried writing the attributes CLASS, IMAGE_VERSION, IMAGE_SUBCLASS etc along the 2D array of data but still it is only considered as a table in HDFView. How can I set the data type to be "Image"?
Thanks a lot
Peter
Message 1 of 8
(6,286 Views)
The Picture data is a 2D array of something, right?  Simply "wrap" it in whatever the HDF5 format requires (or hand it to a routine that will do this wrapping for you) and you'll be done.  If you do a Web search for HDF5 LabVIEW, you might find some examples that purport to do this wrapping ...
Message 2 of 8
(6,237 Views)
I am not familiar with the HDF5 package you are using since I rolled my own a long time ago, but it does work with LV images pretty easily.  As long Live HDF5 includes both hdf5.dll and hdf5-hl.dll then just find the wrappers for the following functions.
Otherwise post your attempt at an HDF5 file and I will try to find what is missing.  You'll probably have to zip it.
Message 3 of 8
(6,223 Views)
Thanks a lot. I tried to store the data as you suggested but the H5IMmake_... function always returns the -1 error. Attached you find my VI and the created hdf5 file. Any clue what I'm doing wrong?
Peter
Message 4 of 8
(6,208 Views)
My HDF5 code is in LV15, please save your VI for that version.
Also, post one of the files that HDFView shows as a table.
Message 5 of 8
(6,198 Views)
I attached the LabVIEW-VI saved for LV15. Might it be that you are using an other version of the hdf5 dll set?
Peter
Message 6 of 8
(6,184 Views)
Accepted by pegli
As I suspected, just a couple of quick datatype tweaks on the CLFN, the width and height are U64 and the image data is [U8].
Message 7 of 8
(6,179 Views)
Darin, thank you so much for the fixed VI. It works perfectly!
Now, I changed the VI in such a way that it integrates with the file open/close stuff from Live HDF5 by UPVI and attached it to this post. Might be, that somebody wants to use it in conjunction with this specific HDF5 package as I do.
Peter
Message 8 of 8
(6,161 Views)
