12-28-2016 10:59 AM
How save multicolumn listbox to file? Because now if i try save (click "ZAPISZ") listbox is clearing, even i click cancel in prompt dialog. Why is this happenning?
12-28-2016 11:06 AM
Try putting those latching booleans INSIDE the event that handles the value change.
You really need to read those latching booleans to unlatch them![]()
12-28-2016 11:12 AM
That doesnt help.
12-28-2016 11:28 AM
OK, So I took a closer look after you fixed the first glaring error.
And.... Just what Values do you expect to place on the Shift Register when you handle any event that outputs the default value for the 2D array of strings output tunnel?
You really need to wire the input to the output. HINT: Right-click the output tunnel and select "Linked input tunnel>>Create & Wire unwired Cases"
12-28-2016 11:36 AM - edited 12-28-2016 11:37 AM
Ok i think is now good. Can you test and tell me it works fine?
12-28-2016 12:07 PM
?????. What are the requirements? Do you have a Unit Test? Did you press the Run Arrow?
12-28-2016 12:39 PM
Sorry, i wrote it wrong. It looks like may work fine? I dont have any errors, but you are master and your skills in LV are perfect.
