Save Panel Image to File.vi
I use "Save Panel Image to File.vi" with LabVIEW 6i, it works with *.bmg,
and not with *.jpg. Have anybody a idea about this problem?
(2,726 Views)
I just tried that and it works fine. I assume that you are using "Get Panel Image" method using VI server to do that and it is the correct way. Are you using the "Write JPEG File.vi"?
Abdullah
(2,727 Views)
