Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Save Panel Image to File.vi
csr
Member
02-13-2001
05:00 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I use "Save Panel Image to File.vi" with LabVIEW 6i, it works with *.bmg,
and not with *.jpg. Have anybody a idea about this problem?
0
Kudos
Message
1
of 2
(2,848 Views)
Reply
Re: Save Panel Image to File.vi
JellyBeans
Active Participant
02-13-2001
10:26 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I just tried that and it works fine. I assume that you are using "Get Panel Image" method using VI server to do that and it is the correct way. Are you using the "Write JPEG File.vi"?
Abdullah
0
Kudos
Message
2
of 2
(2,848 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
