Save Time from a waveformchart
Hello everyone,
I want to save the timestamp of my measurements. With my actuall programm I can save the Y data (Stromstärke) of the waveformchart (see apendix) with a spreadsheet file.  How can I save the equivalent X data (Time) in the same file, so I can get the following form "Stromstärke, Time", saved for each measurement?
Thanks for any Help!
Cheers
Jay
(3,105 Views)
Hi Jay,
waveform charts don't handle any "Time" on their X axis, they just count samples.
So you could just use the loop iterator and scale it's value with your dt loop setting.
Btw. using a TimedWhileLoop on a WIndows target is nonsense. It's also nonsense to use FileIO functions in a timed loop…
Out of interest: which CAN device do you use and which CANopen functions library?
(3,102 Views)
If you write waveforms to the chart, the T0 (and dt) of each waveform you write is in the history.
But with what the OP has, I would just use Build Waveform.  Y is obviously the data.  T0 is the timestamp that is already in there.  Just need to fill in dt with whatever the sample rate is.  Then use Export Waveforms To Spreadsheet File which will write the timestamp for each element.
(3,076 Views)
Hey Gerd,
thanks for your quick response!
I am have a PXI-8531 and I am using an analogue Transmitter Modul (Transmitter-Modul: http://www.microcontrol.net/fileadmin/maindownload/manual/hb_mcan_trs_v2r00_de.pdf), which supports CANopen.
Actually I am new to Labview and I don t know what makes sense in the programm. I used a TimedWhileLoop like in the examples for CANopen. What type of loop and type of file would you consider?
Does another way exist? Thats only the data of 1 Modul and I must connect 8 together. I must be able to know which data was send in which timestamp from every Modul. So I am no sure if using the loop iterator and scaling it will solve the problem.
Cheers
Jay
(3,067 Views)
