Save a cluster in a file
Hi! i'm trying to save a file with some data of my application. This Data is a cluster of some boolean data, some i32 data, some array of i32 and some string data. I use OPEN_CREATE_REPLACE File.vi, WRITE FILE and CLOSE FILE to create and replace file and works fine. But when i create the EXE file, this sistem will not work anymore. why? (If i create a more simple cluster i.e. a boolean data+ a i32 data, this work)
Thank you very much to anyone that try to respond to my question.
Andrea
(3,132 Views)
this should work.
Make sure that :
- When building an appplication, the location of your files may change (one more "strip path"-function needed)
-Another way : first use "Flatten to string" function, and then write the string". After reading the string, you can use the "Unflatten from string function".
(3,132 Views)
Hi Andrea,
I am curious to know what does not work when you are trying to write the complex datatype to file. Does the exe give you errors? Are these errors related to File I/O?
There are a few examples that ship with LabVIEW that may be very useful to you. Please look at Help >> Find Examples >> Fundamentals >> File Input and Output >> Write Datalog File Example. If this one works for you, you can use the Read Datalog File Example to read the data back.
Feroz
Applications Engineer
National Intruments
(3,132 Views)
Hi Andrea,
Feroz
National Intruments
(3,132 Views)
