Save a file in a very particular path - help needed
It is necessary, otherwise it will error if a directory you are trying to create already exists and everything will fall over!
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 21 of 39
(1,165 Views)
in which way can i handle error?
new dir.VI --> no error (my path didn't exist and now it's created) --> build path --> save file
new dir.VI --> error (my path existed) --> build path --> save file
is it correct?
i don't thinks so...in this way i recognize if my path existed but in my control i do the same things... i use build path VI and i save my file in it
Using LabVIEW 7.1
Message 22 of 39
(1,159 Views)
is it correct?
Yes
Sorry Dont understand what you mean
Message 23 of 39
(1,156 Views)
after NewDir VI i make the same things, if there is error or no error 🙂
Using LabVIEW 7.1
Message 24 of 39
(1,153 Views)
So is your problem fixed?
Message 25 of 39
(1,151 Views)
no, i make as in image but it doesn't work...
in this way i can't find new dir, and i can't find my file too...they didn't wasn't create 😞
in image i show both cases, with error and without error...
from datalog file name subvi i got my relative path, that i would to sum to datalog path.
Using LabVIEW 7.1
Message 26 of 39
(1,147 Views)
Below are two screenshots which shows the true and false cases. Hope that helps
Message 27 of 39
(1,136 Views)
if you have time could be so gentle to explain me your program? why is it done in this way?
i'm trying to understand it but... 😞
Using LabVIEW 7.1
Message 28 of 39
(1,130 Views)
Go back and look at my example.  In it you will see that I am looking for a particular error code (10).  This error code is generated when you try to make a directory that already exisits.  If you get this error, simply clear it.
Message 29 of 39
(1,123 Views)
the icon to create folder what is?
in labview 7.1 i don't find it...what can i use? the mine one, new directory?
Using LabVIEW 7.1
Message 30 of 39
(1,119 Views)
