Save a file in a very particular path - help needed
Yeah, they changed it somewhere along the way (I think going into 8.0).  The New Folder should be it.
Message 31 of 39
(1,067 Views)
in my case error 10 is duplicate path...is that?
Using LabVIEW 7.1
Message 32 of 39
(1,066 Views)
yep
Message 33 of 39
(1,048 Views)
do you think is correct? i can't test it now 😞
from datalog file name i have a relative path that i would add to datalog path
PS: why i have to monitor error out coming out from create new dir?
is it possible don't consider errors in and out from craetenewdir? erasing totally them...
Using LabVIEW 7.1
Message 34 of 39
(1,039 Views)
it doesn't work 😞
Using LabVIEW 7.1
Message 35 of 39
(1,017 Views)
Instead of complaining that it doesnt work, please try and do some debugging on your code and post messages with a bit more information.
http://www.ni.com/gettingstarted/labviewbasics/debug.htm
http://k12lab-support-pages.s3.amazonaws.com/lvadvancedhome1.html
If not at least get a more current version of Labview so that people here can help you.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 36 of 39
(1,006 Views)
it doens't create the folder, or the file...nothing
and i can't use a better labview
Using LabVIEW 7.1
Message 37 of 39
(998 Views)
It sounds like they changed the create folder going to LabVIEW 8.  You need to create each folder going down to your final subfolder.  The most common trick I've seen to do this is to use the Strip Path in a while loop.  Have the resulting paths autoindex out and stop the loop when you get a Not A Path.  You can then reverse the array and create the folders in a FOR loop (autoindex on the array of paths).
Message 38 of 39
(988 Views)
Anyone wants to play a game of 'predict the next question'? Smiley Wink
Message 39 of 39
(979 Views)
