Save data starting with 0 second
Neither %S%d nor %S nor %d provided the result that I want. It didn't start from zero in the save file. With %S%d, the time in the file was starting from 0301, 0302 ... which is wrong.
I put the delay function in the sub vi because I want the user to be able to adjust how fast the data is saved.
Message 21 of 36
(2,420 Views)
If you want the time to start at 0 you will have to place your initial timestamp in the loop itself and get it at the same time you get the iteration timestamp. This will only be done the first time you execute the loop. Place this timestamp into a shift register and use that value for all other iterations of the loop.
As for the time being in teh subVI it is still a very poor design. This is effectively a task of the UI of your program and should be done at that level. The subVI should simply be called and do its work. No delays or anything else. What would happen if someone tried to use this subVI in another program. They may not want the delay or have some other method of controlling when this subVI is called. By place the wait in the subVI you have made this subVI much less reusable.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 22 of 36
(2,414 Views)
Your subVI should not have any time function at all. That includes a wait and any format to time string. This is much simpler than you are making it.
Message 23 of 36
(2,409 Views)
@Mark yedinak
As you can see in my attached vi, you mean I should add a shift register instead of the tunnel?
My sub vi might be a poor design containing time delay but the purpose is to make the user enable to adjust how fast the data can be saved. This probably is the only way to do it.
Message 24 of 36
(2,400 Views)
@ Mark Yedinak,
I would appreciate if you can adjust directly in my code. I already tried what you have said but it didn't work.
Message 25 of 36
(2,395 Views)
Accepted by Bombbooo
Here is the VI.
Mark Yedinak
LabVIEW Champion
Message 26 of 36
(2,382 Views)
Could you please save it in 2010 version? thanks
Message 27 of 36
(2,373 Views)
Here it is.
Mark Yedinak
LabVIEW Champion
Message 28 of 36
(2,362 Views)
Thank you for adjusting my code. It does starts from zero. However, when it reaches 60, it comes back to zero again which is supposed to be 61 instead. How can I program that?
Message 29 of 36
(2,358 Views)
You could modify the format specifier for the Format String to include the minute value. Or you could simply format the difference you calculated using a regular format string (or format number into string).
Mark Yedinak
LabVIEW Champion
Message 30 of 36
(2,355 Views)
