Save data to spreadsheet
Hello All,
I need to write 2D array of data to spreadsheet.
Every time I press some button, new file should be created with date and time in file name.
Can someone advise how to create this?
Thank you.
Milan
Message 1 of 11
(5,492 Views)
Hi Milan,
which of these steps is a problem to you?
What have you tried so far? Where are you stuck?
Use FormatIntoString to create a file name according to your needs. (FormatDateTimeString might work too.)
Then use BuildPath to create a valid path for your desired file.
Then use WriteDelimitedSpreadsheet to save your 2D array…
Message 2 of 11
(5,479 Views)
please check attachment.
First I have problem creating subfolder, where all files will be saved.
Best regards.
Message 3 of 11
(5,473 Views)
Hi Milan,
I cannot check the VI as I only have LV2017 available right now. (You might attach a snippet or a downconverted version of your VI.)
To create a subfolder you can use this CreateFolder function…
Message 4 of 11
(5,469 Views)
Hi Gerd,
I tried with create folder first...
and with build path
Message 5 of 11
(5,458 Views)
Hi milan,
error 10: you should not try to create an already exisiting folder…
error 43: you cancelled an operation, so it is not the fault of BuildPath…
Message 6 of 11
(5,447 Views)
i manage to create folder, but write spreadsheet always ask to chose file to write...
I need to create file, not to open existing one...
Message 7 of 11
(5,440 Views)
Hi Milan,
what is the full path that you feed into WriteDelimitedFile?
Does it contain a valid path, with all folders already existing and a valid filename?
Edit:
Found the problem - by debugging…
Look inside WriteDelimitedFile: inside WriteSpreadsheetString a new file is opened without providing a filepath. This will trigger the FileOpen dialog…
(You should have found out that too - by debugging…)
Solution:
Create the file on your own using FileOpen. Then convert the string using ArrayToSpreadsheetString. Then write that string using WriteToTextFile. Don't forget to close the file afterwards…
Message 8 of 11
(5,427 Views)
Hi Gerd,
I tried that way, but problem is obviously when I append file name (date, time) to the path, then probe shows that this is not a path. Of course, because this file doesn't exist yet. Why cannot create file with specific file name?
5.PNG5.PNG  Thanks
Message 9 of 11
(5,414 Views)
Accepted by milan87
Hi Milan,
there are several forbidden characters in filenames. The colon (:) is one of them!
(This is basic knowledge for using computers and not related to LabVIEW.)
Message 10 of 11
(5,407 Views)
