Save data upto completion
Hai I had 9 vi's. Each one is linked through system exec. From starting to end each data should save in one file. Each vi showing in different window. How to append each data in one file
"Thanks with regards "
by
..........Gireesh..........
Message 1 of 24
(5,537 Views)
Do you mean you want to save all the output from the 9 vis to the same file?
Message 2 of 24
(5,527 Views)
Yes, exactly
by
Message 3 of 24
(5,522 Views)
Did you try it out? are you getting any error?
Message 4 of 24
(5,516 Views)
Accepted by gireesh
Message 5 of 24
(5,507 Views)
I didn't try it. I have no idea how to connect these data to a single file
by
Message 6 of 24
(5,496 Views)
After seeing this message thread, and your other one, I am wondering what you are doing that relies so heavily on your use of the SysExec function.
What are you doing?  What is requiring you to use SysExec?  Give us a big picture explanation of your project and not just these different questions about different details that use SysExec.  I'm getting the feeling you are going down a path that is making things far more complicated than they really should be.
Message 7 of 24
(5,488 Views)
Actually I am in a travel.i am sending through mobile. So I cannot try this and the link. I read the link. Once I tried spreadsheet with append file. but it saved as different file and named as 001,002 etc. Sysexec was used at the end me the program for calling the next program. I saved the programs in exe form. That's why I used sys exec.
by
Message 8 of 24
(5,471 Views)
That really didn't clarify anything.
"Once I tried spreadsheet with append file. but it saved as different file and named as 001,002 etc"
You tried onc?.  Maybe you should have tried a few more times.  If something wasn't working right for you there, then you should have tried solving that problem.  Sequential files sounds like something you might get from using an Express VI to create the files.
How would creating different .exe programs help that problem?  Stringing together multiple .exe 's by way of SysExec in LabVIEW really sounds like a hacked up program.
Message 9 of 24
(5,447 Views)
hi gireesh,
  Why dont you place each vi in a flat sequence/stack sequence and what ever the string outputs you are getting ,concatenate and at the last frame you write the whole concatenated string in a text file.?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 10 of 24
(5,442 Views)
