Save graph setting to previous last used setting
Hi Kirit,
since you decode an INI- style- string by yourself, you only have to load that string from file at program start. Use "Read from Text File" from the File- palette. Use "Write to Text File" to store your Config- String to file.
In my VI you had to press the STOP- button, to execute the code which saves the settings to file. To illustrate this, i recommend running the VI with execution highlighting ON (press the light bulb in the toolbar before executing). If You press the Close- button in the title bar, the program is aborted immediately (while running in the while- loop) and cannot save anything to file!
With the event- structure from the Structures- palette you can react on closing the front panel. Search in the "Example Finder" for "Event tracking.vi"
Hope this helps,
greets, Dave
Greets, Dave
Message 11 of 12
(673 Views)
Hello Dave
I took a break from the current project, now i am back in resuming the project. It's just not this coding what we discussed, its just a correction we needed in that program.
I couldn't implement that logic in my code, can you please help me in achieving this task.
I am sending the llb file in which you have the "read XY config.vi" where we have to implement the logic which you suggested in "example of property node mod_LV851.vi".
Thank you
Regards
Kirit
Message 12 of 12
(636 Views)
