Save image from picturebox
I have an image in a PictureBox (.NET).
Is possible to save the image showed in the PictureBox in an archive (.jpg, .bmp or others formats).
Thanks!
Message 1 of 34
(11,180 Views)
Take a look at the Graphics and Sound>>Graphics Format  pallete.  There are vi's there that will take an image and write a JPG, BMP or PNG.
Message 2 of 34
(11,167 Views)
The code will look something like this:
Message 3 of 34
(11,165 Views)
jmcbee,
the main problem ís:  "How to trasform pictureBox data into picture format?"
If I do this transformation, I will be able to use the VIs that you showed.
Thank you for help.
Message 4 of 34
(11,128 Views)
The .NET PictureBox isn't the same as the picture control. jmcbee has them confused. Smiley Wink In order to save a the image in a .NET PictureBox you need to get the image (via the Image property) and then call the Image class Save method. This is documented on MSDN.
http://msdn.microsoft.com/en-us/library/system.windows.forms.picturebox.image.aspx
http://msdn.microsoft.com/en-us/library/system.drawing.image.save.aspx
Message Edited by smercurio_fc on 03-15-2009 09:36 AM
Message 5 of 34
(11,119 Views)
smercurio_fc,
I tried to save the image from .NET PicturBox via Image Property and calling the Image Class Save (String: Filename) but I hadn't success.
I'm not passing the path in the wright way. The VI always return the error NULL ObjectId.
Could Anybody help me!?
Thank you for help!
 Front Panel Error
Block Diagram
Message 6 of 34
(11,106 Views)
That indicates that the Image object was null, hence the Save method couldn't work. How is the image being loaded into the PictureBox? Can you post your VI?
Message 7 of 34
(11,089 Views)
The complement of the Block Diagram is right down.
Thanks for help!
Block Diagram  - Part2
Message 8 of 34
(11,082 Views)
It would be a lot easier if you just posted your VI. I have no idea what that avicap32.dll is. Whatever it is, it's probably not setting the Image property so that you can use it later. What version of LabVIEW are you using? If you're using something more that 8.2 than you should be using the error clusters on those Call Library Function Nodes to provide your data dependency for execution flow, rather that a sequence frame.
Message 9 of 34
(11,046 Views)
Hi fernandob...,
there is also a command (SendMessage cmd) to send the image to the clipboard, you can then read it from there and store it to a file.
See this link http://social.msdn.microsoft.com/Forums/en-US/csharpgeneral/thread/ff7893d5-0060-4456-ad25-8a331d8b4...
Mike
Message Edited by MikeS81 on 03-16-2009 03:08 PM
Message 10 of 34
(11,040 Views)
