Save string of data in array and control from array
I have a questions about arrays.
As shown in "Save array.PNG",
1) I need to save the item name and value inside 1st row when "Save ASCII" button is pressed.
2) Save the item name and value inside 2nd row when "Save Hexadecimal" button is pressed. (hex input will be converted to ASCII format before saving in array).
Will keep continue to save into the array when new input is entered.
Then i need to make this array to become control so that i can choose it like in combo box as shown in "Combo box.PNG".
The VI is attached below.
Anyone can please help me to solve this? Thanks.
(4,944 Views)
Accepted by topic author oliver1023
Use listbox:
(4,934 Views)
I done the block diagram but when i press save, it saved 2 times
(4,924 Views)
Use insert photos instead attach.
And without your code I can't say where is mistake
(4,918 Views)
All done and i've debugged the problem.
(4,887 Views)
