Save the 3 indicators (Missed, False hits, Actual Skips), including the participant's name into a text file in LabVIEW and send the text file by email to another person.
  • Please keep the subject short and put the question details in the body of the message.
  • Please don't maximize the front panel and diagram to the screen.
  • Your iteration takes at least 1.5seconds, so what you wire to N is NOT "number of seconds to run the test"
  • I think you can significantly simplify your code as we discussed long ago.
  • There is an entire file IO palette and there are tools for e-mailing. Did you find them yet?
Message 2 of 8
(2,957 Views)
guys how to save the 3 indicators (Missed, False hits, Actual Skips), including the participant's name into a text file in LabVIEW and
send the text file by email to another person example once the Mackworth test is completed, the missed counts, false hits, etc parameters will be written into a text file.
This is all done in the same VI.
After that, the text file is sent via email to a email address. This could be the same VI or a different VI.
Message 4 of 8
(2,945 Views)
Check out the "File I/O" palette. It has all the necessary tools to save data to a file. If You want LabVIEW to send the E-Mail for You, You will probably want to use some of the connectivity tools - depending on what exactly You want to do on what kind of system, which I am unable to guess.
Message 5 of 8
(2,914 Views)
To save the data into a file, use the Vis in the I/O file palette. Open file, write text file, close file. You will need to format into string (a vi as this name in the string palette) your integers.
Then to send an email, use the palette SMTP in Data Communication>Protocols>SMTP email. Don't use the express VI as you can't add attachements. Use Open handle, Set recipients, Set message, Set attachements, Send.
Yddet
PS: LLindenbauer has been faster than me
Message 6 of 8
(2,907 Views)
hi regarding the smtp email i have created this vi but would like change to attach file instead. Anyone can help?
Message 7 of 8
(2,898 Views)
Accepted by gavinng
Your question has already been answered. Use "set attachments" and the other tools in the SMTP palette. See also the second part (2013+) here.
Message 8 of 8
(2,832 Views)
