Save to new VI
How to save a graph to a new VI from a Running VI ?
(2,908 Views)
Your description of problem is obscure.
Could you please provide more details on what you want to achieve??
That way we could help Better
Dev
(2,905 Views)
Hai Dev..
Thanks for your reply yesterday.It worked.
Now I have a main VI in which i calculate some values and give those values to a XY graph and I want to save this graph to a new VI with different name and i have to do this while the main Vi is running.
How Can i do it?
(2,900 Views)
I understood what you are tring to do
But 2 more questions:
What is the reason that you want to do this?
And do you want to do this programatically??
I ask this because,if you just explain the background, maybe we could suggest a simple method
(2,880 Views)
Yes i want to create new vi programatically.
It will be a great help if u could provide a simple method.
(2,868 Views)
Hai,
Not clear about your requirement.
When you are looking for creating new vi's from existing make use of VI templates.  i.e. you can place the XY graph in a *.vit (vi template) and each time you call the template will generate new instance of it which you can save as VI.
Is the above is of help??
With regards,
JK
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,858 Views)
