reading datas from OPC server
can i able to read data from msi opc server on labview?......
tell me some good suggestion and what may be the procedure to do this? and send me the related docments and manuals for this
Balaji DP
(2,857 Views)
look in NI examplefinder  -   the vi  called   "Browse To OPC Item.vi"    and other's should do the job for you
(2,856 Views)
i know this method to read the data throug opc... but here i have more than 50 channels data, i cant able to do that all channels to this way....
is it possible to do  using  ni-psp or through ni-opc server, right now i dont have ni-opc server with me.... if its with me will it shown these msi opc server channels data tags on ni-opc server?...
Balaji DP
(2,846 Views)
Hai balaji dp,
With OPC servers you can handle upto 10,000 tags.  These tags (url) can be created with the NI OPC server interface. Datalogging and supervisory control Module (DSC module) is more sophiscated interface to carry out the OPC communication.
With regards,
JK
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,837 Views)
