Save with options - target path question window is invisibel
Hi all,
I have a weird situation:
I had some minor changes to an existing project, which implied the addition of some subVIs from other projects. To have those in the project library I wanted to save with option as devellopment distribution. Doing so takes the focus from LabVIEWs window, but the window to select the target directory is not visibel.
I imagined this could be caused by a change in my display settings I had performed recently, but anyway - I need to resolve this.
Anyone having a clue where this windows is located and how to bring it  back  into the visibel area of my screen?
i have searched the LabVIEW.ini for some related info but did not come up with anything.
Any help?
Greetings from Germany!<br>-- <br>Uwe
(2,430 Views)
Problem not solved, but I found a way around it: I just disabled the setting Options/Miscellaneous/Use_native_file_dialog and got a visibel file dialog.
But I'd prefer the native dialog so problem did not disappear ;-((
(2,419 Views)
