Saving Traditional NI-DAQ device Accessory configuration in MAX
I currently have a data acquasition system that uses MAX to control settings for virtual channels and Scales and a SCC-2345 accessory w/ 9 modules.
I would like to save the list of SCC-2345 modules that are used in the system, but using: "Tools>Traditional NI-DAQ configuation>save configuation" only saves the virtual channel and scale settings, and exporting configuratons from the file menu only works for DAQmx. This forces me to set-up the 16-channels of modules every time I switch from monitoring a different accessory box.
This is quite frustrating, but I know how to deal with it.
Now, this piece of equipment has been duplicated and sent to over-seas, and they would like a turn-key solution, which is almost what I have as far as software goes, with the above caveat.
Is there a way that I can save the module configuration settings for the SCC-2345 in Max (saving traditional NI-DAQ accessory configurations)? Or is there a different way I should be going about solving this problem?
-anyone?
-Nick
Nick
(2,557 Views)
-Buhler?
Nick
(2,552 Views)
I am not familiar with a way to do this in Traditional DAQ -- why is DAQmx not an option?
Regards
(2,538 Views)
