Saving an Image from VBAI using shared variables and LabView
    I have a smart camera NI1752 connected to my PC via a PLC.  I am able to get the image and do an inspection.  I would like to save the image onto the system.  There is some issue with the Image logging via FTP function in VBAI.  Hence I am trying to use shared variables and create a Labview vi to do this function.  I searched online for methods of using shared variables.  When I execute a VI in labview (with shared variable set in VBAI), I am able to save the image using the shared variable but I want to trigger this automatically when an inspection is run in VBAI.  (I dont want to have labview open always).  Hence I added this vi to VBAI using LabView vi option.  But now there is no image being saved.  I made the Vi under the smart camera which I added to the project.  (The camera is in Labview Real time mode).  I am not able to add vi in VBAI mode.
Can someone tell me if there is any mistake in my procedure?  Or I would really appreciate it if someone can tell me the correct method.  I have attached the vi.
Best,
Joe
(3,474 Views)
Hello phoenix_777,
Since its been a while since you asked this question, I will like to start asking if you still require help.
Please let me know if you still have questions.
Regards
Randy @Rscd27@
(3,362 Views)
I found an alternate solution to the problem.. So this question can be considered as closed
(3,360 Views)
Glad to hear that. Let me know if you need more help.
Warm Regards,
Randy @Rscd27@
(3,357 Views)
