Saving and Restoring Pump Operating Hours in LabVIEW
Which way would you recommend? Show me the step-by-step process? Would it be using Write To Measurement?
Message 21 of 33
(320 Views)
Hi Felipe,
We told you here, here, here, here, here to save inside the loop.
You even noticed this suggestion before…
Message 22 of 33
(316 Views)
I put it inside the loop and it gave this error
Message 23 of 33
(309 Views)
You probably want to close it after the loop, right?
Message 24 of 33
(301 Views)
I already have a while loop running in my program, and it can't be interrupted. Within this same loop, I need to implement the hourmeter logic.
The goal is that, every time the pump is turned on, the system records the time it was on and increments that value to the total accumulated until the pump stops.
The problem I'm facing is that, because of the way the while loop is already structured, a conflict is occurring when trying to read and write this hourmeter logic within the same loop
Message 25 of 33
(291 Views)
Hi Felipe,
why are there backward wires in the last image?
You cannot write to a file once you close it...
Message 26 of 33
(282 Views)
I believe the image is disorganized, I apologize, here is the image
Message 27 of 33
(273 Views)
Still disorganized and you still close the file reference in the first iteration, making it invalid for the rest of the run.
Message 28 of 33
(256 Views)
Did this image look better?
Message 29 of 33
(249 Views)
Accepted by topic author Felipe_Alves17
Hi Felipe,
Nope, still backward wires!!!
See this as a suggestion:
  • When you close a file then you cannot use its reference in the next iteration! Solution: open the file again…
  • All wires going from left to right: did you ever read the style guide in the LabVIEW hellp???
  • As noted in the image: you need to implement error handling!!!
  • Please don't name VIs with "FINAL" when they clearly aren't finalized…
Message 30 of 33
(243 Views)
