Saving current graph data
Accepted by glskinner84
You could do this if you don't mind your DAQmx buffer filling up while it's frozen. In addition, you could add code to check whether freeze is changing value and start/stop acquisition accordingly. Or you could change your acquisition type to be On Demand instead of continuous.
Cheers
Message 21 of 41
(4,212 Views)
I'm running labview 2012 and can't view the snippet 😞
Message 22 of 41
(4,205 Views)
I'm currently dling 2015.
Message 23 of 41
(4,189 Views)
I see, attached I've made a VI which more addresses your problem - Pause Acquisition (2012). You will want to put your acquisition code in the ["",Default] case of the case structure. I've also included the Freeze Updates VI for your info.
Edit: I don't mean it addresses it more than James, I meant it addresses it more than my previous "Freeze Panel" suggestion 🙂
Message 24 of 41
(4,183 Views)
I'm looking at James' vi from another machine. James, in the case stucture...under the true case...it has a ms timer with 100ms constant and the graph leads straight to the measurements VI. So, this stops aquisition and passes what's left in the graph buffer to the measurements VI? How much data does it save?
I'm about to look through yours too Greg.
Thank you guys for the help. I do appreciate it.
Message 25 of 41
(4,167 Views)
Here's my snippet in 2012 form.
It's not a graph buffer, it's the graph itself. Since you're writing new data to the graph every time, you're overwriting the previous graph data. This writes the same data that is showing on the graph and since the acquisition is in the other case, the graph isn't changing.
Cheers
Message 26 of 41
(4,164 Views)
The Waveform graph local variable in James' VI will give you what was last sent to the waveform graph.
Message 27 of 41
(4,159 Views)
You guys are awesome. James solution works perfectly...my only complaint is the time it takes for the graph to stop...it seems like once I hit the Freeze button it refreshes the graph once more before stopping...but if I turn the source off and push the Freeze button at the same time, I get my decay.
Greg, your P/C version will come in use later...when I'm building on this program to take automatic readings...I need to get a AO first though.
Message 28 of 41
(4,136 Views)
Also, what if I run into buffering problems?
Message 29 of 41
(4,129 Views)
It will freeze after the current loop finishes acquiring data. This is the nature of you reading a certain number of data points. If you wanted to update faster, you would probably have to use a chart instead and pull smaller groups of samples.
For buffer issues, change your acquisition type to On Demand instead of Continuous. This will work for you as long as you dont care about a sample or two disappearing between each loop.
Cheers
Message 30 of 41
(4,126 Views)
