Saving data to a USB-stick with cRIO 9012
Hi all,
could somebody tell me how I can save data to a USB-stick using the USB port on a cRIO 9012?
I have searched a lot (including the examples), but can not seem to find it anywhere. Is it posibly so simple I'm not seeing it?
If you could give me an example, I would be most appreciative.
Thanks in advance
(Using LabVIEW 8.2)
(3,207 Views)
Hi jbont,
A USB drive is generally mapped as u:\ and LabVIEW can access it as such. Check out the following Discussion Forum that has more details and an example.
http://forums.ni.com/ni/board/message?board.id=170&message.id=222880&requireLogin=False
Additionally, you can use the console out and a terminal program to see what drive letter is mapped for the usb port.
Hope that helps,
Steve
(3,204 Views)
Hi Steve, thanks a lot. This really helped. I don't know how I could have missed this discussion. Thanks again. Joep
(3,199 Views)
Glad it helped out.  Have fun programming.
Steve
(3,195 Views)
