Use discret signal with Event Structure
Is it possible to use a discret signal (from PXI-6511) as an event for the Event Structure?
Instead of executing some code when a button of the form is pressed, I would like to use a real button connected to a digital board.
Thank you!
(3,300 Views)
Do you want a trigger? because you don't need an Event Structure with a trigger.
What do you want to do with this button? Data acquisition, ... ?
Can you send your VI?
Regards
VéroniqueD
NI France
(3,266 Views)
Yes, I will have a button connected to a NI PXI-6511 board, and I would like that when I press the button it starts to do some acquisition and some processing of the data acquired.
I thought in doing a loop where for each iteration I check the discret signal, but maybe there's a better way, like a trigger that would execute some labview code when detects that discret signal.
(3,263 Views)
I think that the trigger is the best choice.
here an example.
VéroniqueD
NI France
(3,260 Views)
I can't open these files. I have Labview 7.1.1.
Could you convert them?
Thank you!
(3,261 Views)
Here is a screen shot
Message Edité par Véronique D le 03-02-2007 10:14 AM
VéroniqueD
NI France
(3,229 Views)
