06-12-2012 07:54 AM
You're passing a folder path instead of a file path, in your first case of the stacked seq, you create a folder based on date, it's good it you want to hav all your measurment data in the same place, but you also need to build a tdms file name to pass to the open tdms primitive.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
06-12-2012 08:07 AM
I'll give it a try. ![]()
06-12-2012 09:50 AM
Why is the # of columns limited to 256?
Is there a way to circumvent this? ![]()
06-12-2012 10:39 AM
I didn't even know that...
Work-around will be to split into groups but that won't help you very much...
Epictetus
06-12-2012 10:48 AM
@CP Miika wrote:
Hi TiTou,
I'm using a stacked sequence. TDMS 1 shows the folder creation and TDMS 2 shows where this path is fed to TDMS open.vi via sequence local.
I hope you can help me.
Please don't upload bitmap images to the forum. There is a reason they are banned. They are too large. And renaming them to a .jpg just to get around the ban is a no-no.
Please attach the images as actual JPEG files, or better yet, as .png files.
