Saving image data to text file - multiple columns
Accepted by topic author CP Miika
You're passing a folder path instead of a file path, in your first case of the stacked seq, you create a folder based on date, it's good it you want to hav all your measurment data in the same place, but you also need to build a tdms file name to pass to the open tdms primitive.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 11 of 15
(1,307 Views)
I'll give it a try. Smiley Happy
Message 12 of 15
(1,304 Views)
Why is the # of columns limited to 256?
Is there a way to circumvent this? Smiley Sad
Message 13 of 15
(1,298 Views)
I didn't even know that...
Work-around will be to split into groups but that won't help you very much...
Epictetus
Antoine Chalons
Message 14 of 15
(1,295 Views)
@CP Miika wrote:
Hi TiTou,
I'm using a stacked sequence.  TDMS 1 shows the folder creation and TDMS 2 shows where this path is fed to TDMS open.vi via sequence local.
I hope you can help me.
Please don't upload bitmap images to the forum.  There is a reason they are banned.  They are too large.  And renaming them to a .jpg just to get around the ban is a no-no.
Please attach the images as actual JPEG files, or better yet, as .png files.
Message 15 of 15
(1,292 Views)
