Saving measurment data to a text file or Excel file
Actually that's a snipett of a shipping example of writing to TDMS with DAQmx
I Jinged a "how to" drag-n-drop a snipett here
But, going back through your original post I see you are not using a DAQmx device so.... Use the Write to measurements file Express.vi
Message 11 of 18
(1,072 Views)
Ok i managed to get the program running but i only get 1 value in the Excel table which is the very last value i get from the thermocouple when i stop the program. How do i get multiple values?
Message 12 of 18
(1,060 Views)
Put the Write to measurement file vi IN the loop
Message 13 of 18
(1,053 Views)
What if i put the Write to measuremetn vi in a separate loop with a time delay ot 2 secs will it still work?
Message 14 of 18
(1,044 Views)
Most likely not post your updated code so we can see where you are getting stuck
Message 15 of 18
(1,042 Views)
I can't really test the program right now without my DAQ hardware thats why i am asking so man yquestions 😛
Message 16 of 18
(1,040 Views)
The time delay is about useless there  The problem is your tunnel mode  Right click the output tunnel and select "Concatinating"
(Hmmm.... sounds familliar.  Must be a homework party somewhere.)
Message 17 of 18
(1,036 Views)
I am using Lab View 8.5 and i dont have such output tunnel options. The time delay isnt useless because i want to get the measurements every 2 secs. When i put the time delays and write to measurment file vi in 1 loop its working but i also want to get the visualizing of the temperature on the indicators constantly not every 2 secs. Tha'ts why i am trying to put the write to measurment file and time delay in separate loop. Heres what it looksl ike .
Message 18 of 18
(1,003 Views)
