Saving punctual values using write delimited spreadsheet
My problem is quite simple, and my solution should be working according to the documentation. I have a program that runs indefinitely within a loop. Using the iteration counter and the Reminder and Quotient function, I can set a delay on my save so that I don't save data at every loop iteration. To do so, I check whether the remainder is =0 to either save or bypass the save for the current iteration. The problem is that, even though I use a shift register to keep track of the file path and ensured that ''Append to file?'' was set to true, the save stops after the second save iteration. No pop-up windows asking for a new file path or any error occurs: the data just stops saving. Is there any additional steps that are required to re-open a file once the write delimited file function has been skipped once? The image below shows an example of my program loop.
Message 1 of 8
(1,361 Views)
  • Your blue inputs are swapped. the iteration terminal should go on top and 5 at the bottom.
  • It is pointless to place the path into a shift register because it is loop invariant.
  • You can wire the remainder directly to the case structure and make one case 0 and one the default.
  • Currently, you get a save on the first iteration. If you want to change it so the first save is after five iterations, add a "+1" after the iteration terminal.
  • You should define a loop rate. currently is spins as fast as the computer allows.
  • How do you get new 1D data?
  • It would be more efficient to use lowlevel file IO, open the file before the loop, close after the loop, and append a row whenever needed inside the loop. The highlevel file write you are using is opening and closing the file with each call, which is much more overhead.
  • etc.
Message 2 of 8
(1,338 Views)
see if this can give you some ideas:
Message 3 of 8
(1,323 Views)
Not true if he's passing in a blank path some or all of the time to use the "Dialog if empty" feature of the Write Delimited File command on the first iteration and pass it to all others after that.
Message 4 of 8
(1,321 Views)
Yes, in that edge case. Since the terminal was placed outside, I assumed that they pick a valid path before running, else the first iteration would take much longer than 5 seconds (Assuming a 1s loop rate from the diagram comment), thus invalidating all time points. 😄
Message 5 of 8
(1,317 Views)
Where, precisely do you do that?  [Hint -- you might use a second Shift Register ...]
Bob Schor
Message 6 of 8
(1,255 Views)
Accepted by topic author LTSB_Student
As I said, the problem is that the inputs to the Q&R are reversed, so the remainder is only zero exactly twice.
Once the inputs are swapped, you get regularity. 😄
Message 7 of 8
(1,246 Views)
I knew it would be something as simple as that... I haven't tried to remove the shift register, but everything works fine now so I will leave it in. Thanks!
Message 8 of 8
(1,185 Views)
