Saving the clusters as default settings
Dear all,
I am stuck in a small problem and need a bit of Help from you.
In my application, i have a subVI which will take the necessary settings from the user to run the program. These settings i want to store it in a File(or in any other format) so that when the user restarts the program, the saved settings gets updated on the Settings SubVI.
The Settings SubVI consists of Clusters which includes Radio Buttons, Enums, Rings, etc.
I am attaching the Front Panel Pic of the Settings VI.
Pls have a look at it and let me know how can i save these settings in an efficient way.
Ritesh
Message 1 of 11
(3,934 Views)
Accepted by LVCoder
Hi Ritesh,
you can write your own function to read and write the data or you use the "Flatten to XML" and "Unflatten from XML" to store and restore your data.
Mike
Message 2 of 11
(3,930 Views)
Hi Mike,
Thanks alot.
"Flatten to String" and "Unflatten to String" works great.
Ritesh
Message 3 of 11
(3,911 Views)
Hi Mike,
Though Flatten and Unflatten to String works great if i store the data in a Text File.
But, its not giving the correct result when i am saving the same string ina Binary File.
I am atacing my code here. There are 2 clusters. The program first stores Cluster1 to the Binary File, and the reads the same file and O/P the data. The I/P data and the O/P doesnt match in this case .
Pls have a look at it and let me know whats the cause ?
Ritesh
Message 4 of 11
(3,899 Views)
I forgot to attach the control to my previos post.
i am attaching it here.
Ritesh
Message 5 of 11
(3,897 Views)
Hi Ritesh,
with some changes it works for me.
Mike
Message Edited by MikeS81 on 02-11-2009 02:02 PM
Message 6 of 11
(3,895 Views)
Hi Mike,
After amendments, I am still not getting the correct O/P.
 here's the O/P i got.
Ritesh
Message 7 of 11
(3,877 Views)
Hi Ritesh,
connect also a "false" to the "write to binary" function.
Mike
Message 8 of 11
(3,873 Views)
Hi Mike,
Thanks alot.
Its working now.
Ritesh
Message 9 of 11
(3,871 Views)
In the interest of full disclosure, you should know that the flatten/unflatten solutions are relatively brittle to change.  If you change your clusters in the future, you need to keep the old datatypes around so you can read old files.  Even though it takes longer, it is more maintainable to explicitly read and write each element in your clusters.  The configuration file VIs or TDMS work well for this type of thing.  You can also use HDF5, XML, or any other hierarchical file system.  LabVIEW 8.6 and higher includes a generic XML parser.  Which you choose depends on your requirements.
Message 10 of 11
(3,846 Views)
