Sawtooth signal with delay
Hi, I am just starting to learn how to properly use labView: signalexpress and am looking for some guidance on a project. I have been trying to produce a looping signal consisting of a "sawtooth" ramp that lasts for 2 seconds, going from 0V to 1V, and is followed by a 1 second pause in stimulation (in between two sawtooth ramps). I would greatly appreciate the guidance of anybody that can give me a brief step by step in producing this specific pattern. Thanks!
(2,866 Views)
Look at the ramp function to get an array of numbers that define your ramp.  Look at Initialize Array function to create an array of a constant value.  Look at tReverse 1D Array in case you need to reverse the direction of the ramp.  Look at Build Array to concatenate all the individual 1-D arrays together into a single 1-D array.
(2,862 Views)
