extract xy graph's data from generic cursors
Hi,i'm new in this Forum.
In my VI i need to extract xy graph's data from a cursor to another one,how can i do that?
I want to extract all the data between the two cursors,for elaborate it.
Thank you 🙂
Message 1 of 10
(4,941 Views)
You need to show us what you have. Please attach a simplified version of your VI containing typical data.
  • Are the x value sorted or random?
  • Are the x-values spaced equally?
  • What is the datatype of the graph data?
  • You also need to explain what a "generic cursor" is. I am not familiar with that terminology.
Message 2 of 10
(4,930 Views)
Ok i create this VI because it describes perfectly my situation. 🙂
Message 3 of 10
(4,924 Views)
All the answers are in the VI 😉
Message 4 of 10
(4,923 Views)
  • You have a race condition due to overuse of a local variable. Most likely the local variable is read before the graph is written.
  • Why is there no outer loop? Are you using "continuous run mode???)
  • Your two array don't contain any default data. After you place values into them, you need to make current values the default before saving the VI.
  • You code inside the FOR loop makes absolutely no sense.
Message 5 of 10
(4,916 Views)
Accepted by topic author giacom9222
In addition to everything altenbach said, you want the Cursor List: Index property. That will tell you where in the array of data the cursors are.
The attached VI shows how it can work and also how meaningless it can be with common types of XY data.
Lynn
Message 6 of 10
(4,908 Views)
Ok sorry,this version is better.I don't need while loop here,this is only a very small part of my program.
It works,but i can't undertand why it not extract the data correctly...in the graph with the extract data i don't have the portion between the two cursors!
thanks for your time
Message 7 of 10
(4,906 Views)
For xy graphs, the array index has no relation to the x values and your subset makes no sense. You need to check if the x values are in range and discard if they are not. Here's a quick draft.
Message 8 of 10
(4,901 Views)
Thanks John,you solved my problem 🙂
Message 9 of 10
(4,845 Views)
Well, you required "from generic cursors", while Lynn's code uses cursors locked to a plot (as I already suggested here).
It only works if the X-values are sorted, and this cannot be guaranteed in the general case. (have you tried the "random" option in Lynn's code 🐵
It seems wasteful to get the entire cursor list if all you want is the cursor index.
You should also use the max&min function as I suggested. This way the two cursor positions don't need to be sorted.
Also note that if you would use complex data as I suggested, you would only need a single array subset operation, simplifying the code.
Message 10 of 10
(4,837 Views)
