Scaling and Mapping Express VI
Just learning my way around Labview 7 Express and working through the
first example. On page 1-9 of the Getting Started with Labview manual
there is a reference to a Scaling and Mapping Express VI, which is
available from Arith/Compare on the Functions palette.
My problem is that my Arith/Compare palette doesn't have this as an
option and I can't seem to find it available under All Functions
either. My choices in Arith/Compare are Formula, Time Domain,
Numeric, boolean and Comparison.
So I'm wondering if I'm the wrong place, or if I can search a library
of Express VIs which it might be hiding in?
(3,899 Views)
Found it on both the standard numeric palette and on my express palette (has an icon depicting two yellow cubes):
Functions -> Numeric -> Scaling and mapping
Functions->Express->Arithmetic and comparison->Scaling and mapping (the path may vary depending on the palette setup...).
However if you can't find it try searching for it. Click the search button on top of the functions palette and search for the VI.
Could be that it only comes with some of the development systems, we've got the full developer suite, if you only have the basic e.g. it might not be included (?).
(3,899 Views)
Thankyou for your input,but how can I acquire that particular VI, 'cause I don't have it. I'm trying to follow the exact example in "Getting started..." Is there a library I could access that VI from or is it only payware or what?
Another thing are you familiar with configuring VISA sessions with an instrument driver for a Hartscientific multimeter (Temperature Controller) modell 2100?
(3,899 Views)
If you have got it can you e-mail me that VI file?
(3,899 Views)
here are the express VI for arithmetic & comparison palette. put these vi's in the folder under Labview 7.0/vi.lib/express/aritmetic&comparisom. you may also want to reinstall labview
Message Edited by Support on 04-12-2005 03:01 PM
Joe.
"NOTHING IS EVER EASY"
(3,900 Views)
sorry you may want to try to reinstall labview first then if that does not fix the problem then use these files
Joe.
(3,899 Views)
The probable reason that the Express VI is missing is that Hexxagon1 didn't buy the full or professional version of LabVIEW. It doesn't come with the base version.
(3,899 Views)
