add support information
On Windows, under Control Panel "Add or Remove Programs", when you click one of the installed files there sometimes is a line "Click here for support information." This has lines for:
Contact
Support Information
Comments
as well as Publisher and Version.
How do you add this information to a LabVIEW application?
Les Hammer
(2,731 Views)
I strongly suspect the "Click here for support information" is an option with the microsoft installer or MSI. Although LabVIEW uses the MSI for its executables, this functionality is not exposed.
I have tried several times in the past to edit a MSI and it is nontrivial. There are software packages for sale that can help make this easier.
As a workaround, you might consider adding a dynamic VI to your application called About.vi . This way if you go help >> about , your VI will pop up with any information you want it to show.
(2,731 Views)
OK, thanks. I thought that might be the case.
Hey, NI: Any chance for a product enhancement?
Les.Hammer@CompleteTest.com
(2,731 Views)
