Scaling intensity graph Z-ramp with panel - how?
In LV7.1.1 is there any way to get the color ramp associated with an intensity graph to scale with changes in the VI panel size?
I've tried telling VI to scale the intensity graph indicator with the panel and that didn't work nor did telling it to scale all front-panel objects with the panel. The ramp always retains its original size.
(2,610 Views)
I think you are stuck.
As for most of the controls, there is no way to change the size programmatically.
The only thing you could do as work around is to create a picture control (which size can be changed...) to mimick the graph scale...
Chilly Charly    (aka CC)
(2,605 Views)
