Why does the case structure behaves funny?
I have a nested case structure. I find it funny even though I used the constant ring enumerator to execute it
Let's say I have nested case structure X and Y and subdiagrams,  A, B, C and D in X and E, F, G and H in Y.
Whatever the nested case structure, the sequence would go thru A, B and C or D, E and F.
That's how it behaves. When the PC is first switched on and the program is run, X case structure would be selected by ring enumerator before going into sequences, then it would go to B,  instead of A and continue to C but missed out D.
Again it is back to initial state (without aborting execution) and went into same case structure and the sequence go thru all A, B, C and D
and continues like the second run. Why is the first run different from the second run?
And again when it is aborted and run again without rebooting the PC . This time the first run is correct and continues.
I am puzzled and why is that so?
I want to send the attached but file is big and will not be able to run without third party.
Please advise.
regards,
Clement
(2,711 Views)
It is difficult to follow your description. Can you attach a simplified example of your code? Thanks!
(2,708 Views)
