Scan From String Assistance
Hey NI Crew,
Here's a simple one for ya. I'm trying to use the Scan From String to dig through a bunch of data files to find the appropriate files.  I can do it to a certain point.  I'm looking for files that are identified as Passed but also have the .txt extension.  The .txt extension is causing this to not work.  I remove it, and I get all the passed files, but every different type of extension.  What's the magic trick here?  Using LabVIEW 2009, fyi.  So don't send me any VIs beyond that please.
(2,775 Views)
Apply the file extension to the "pattern" input on the "recursive file list" block.
Have fun.
0xDEAD
edited to add: In your case "pattern" would be *.txt
(2,773 Views)
Have fun.
0xDEAD
If the standard wildcards work then a pattern like ?Passed.txt might work better
=== Engineer Ambiguously ===
(2,755 Views)
Hmmm... I mean sure if you wanted to do it the easy way. LOL
Thank you.
(2,752 Views)
If you wanted to keep with the Scan From String, you need to use "%[^.]" instead of "%s".  The bracket notation looks for specific characters and the ^ states not the next character.  To this will take all characters up to the period.  The normal %s looks for a white space to stop the scan.
But the super easy method is to use the Recursive File List.vi and use "Passed_Report_*.txt" as your pattern.
(2,738 Views)
