Scan extended precision numeric from string
I am looking for a way to parse a string to an extended precision floating point numeric. The Numer/String Conversion "Scan Value" function built into LabVIEW 2013 outputs a double. How can I get an EXT?
(3,528 Views)
Accepted by bmhelm
Wire an extended constant to the default input.
Lynn
(3,523 Views)
Thanks! Easier than expected.
(3,515 Views)
If you are not doing so, please keep the Context Help window open while programming. It explains what a function or subVI does when the cursor moves over the icon and provides a link to more detailed help.  It is very useful for determining what inuts are required and how things work.
Lynn
(3,504 Views)
