Scan from string help
Hi all,
From the below string I want to obtain:
VALUE 1 I WANT
VALUE 2 I WANT
VALUE 3 I WANT
These headings or titles of the values will always remain the same in the string.
I'm sure this can be done simply using the scan from string function but cannot figure out the sytax/method.
Thanks.
Random text
VALUE 1 I WANT: 1234
6th June 2016
Random text
Random text
Random text
HEADING 1
VALUE 2 I WANT: string
VALUE 3 I WANT: 1234
Random text
(4,469 Views)
This seems to work.  Just using a couple of Match Pattern functions.
(4,463 Views)
Thanks but is it possible to do it using the Scan from string.vi?
(4,451 Views)
Please  go through the thread linked below
http://forums.ni.com/t5/LabVIEW/scan-from-string-error-85/m-p/3285591
if still facing any problem
(4,429 Views)
This is quite a universal approach:
Greets, Dave
(4,403 Views)
