Scan parameters from string
I'm trying to parse some parameters from a string. I'm unable to achieve it using Scan from string node.
Can anyone help on this? Attached image for reference.
Thanks in advance
(4,453 Views)
Accepted by PadmanabanJ
This is a LabVIEW question isn't it, so should be posted in the LabVIEW forum?
The following format string should do what you want:
<Prop Name='%[^']' Type='%[^']' Flags='%[^']'>
(4,419 Views)
Thanks, It works.
Sorry, I didn't noticed it
(4,387 Views)
I have moved the thread to the LabVIEW board.
(4,381 Views)
