Scanned variable read function - all channels
Does anybody know a way to read all channels of a c-series module with one function? The below archived white paper shows all channels on a module can be read with the scanned variable read function, but when i do this, i get the attached error. I'd prefer one function icon that outputs an array instead of, for example, dragging and dropping 32 I/O shared variables then wiring these to a build array function.
https://www.ni.com/en/support/documentation/supplemental/08/archived--ni-scan-engine-advanced-i-o-ac...
Thanks guys!
(5,491 Views)
What c-series module are you trying to perform the scanned read with? I just tried a 9205 and a cRIO-9033 running LV2017, and it worked without error.
If you right-click the refnum, then expand Select Variable Class, what's the current class type? Note mine is listed as a 9205 Variable Container:
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(5,451 Views)
Good Morning Michael!
My setup details are labVIEW 2015 sp1, cRIO9075 with NI 9213 and NI 9207 modules. i drag & drop a scanned variable read function, click the refnum in, create constant. I then click the refnum drop-down arrow, browse. For both browse options, Variable Engines and Current Project, the module is grayed out so selection is disabled. See attached jpg. i can select individual channels, but not the module. When i manually edit the refnum text ni.var.io://192.168.1.214/Mod1/TC0 to delete /TC0 and run the code, i get an error. Variable class is shown in attached jpg.
i'll start researching the variable classes, maybe it is a configuration issue.
Ryan - CLD
(5,440 Views)
I noticed in my previous post i did not set a data type on the scanned variable read function first before creating the refnum. when I wire a array of double, and try to read Mod1, i get error "-1950678944 Scanned Variable Read in Untitled 4.vi".
(5,437 Views)
Did you check out this white paper too:
https://www.ni.com/en/support/documentation/supplemental/08/understanding-ni-compactrio-scan-mode.ht...
The first one you linked has been archived and was published 8 years ago, the above was last updated earlier this year and deals explicitly with cRIO and the Scan engine
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(5,435 Views)
Accepted by Ryan01
I got it!!! Selecting the correct class was the trick. I did trial and error by selecting every type of variable class one at a time. The below class worked for getting all module channels.
Thanks mike for pointing me in the right direction!
(5,433 Views)
