Scheduling and DAQ assistants
Using flat sequence and DAQ assistants, how can we implement scheduling algorithm to enable or disable a specific frame in the sequence?
(2,455 Views)
Accepted by Noor Tubaiz
Don't use the flat sequence structure! You cannot enable/disable any frame. Just one of the drawbacks of the sequence structure. They are seldom necessary. If you want flexibility, use a state machine.
(2,454 Views)
Thanks a lot, appreciated.
(2,441 Views)
